Post and beam Posted October 9, 2024 Posted October 9, 2024 A neater routing strategy is possible in my build if i drill 20mm holes through the kicker blocks at the insulation/screed boundary height. In my ignorance i cannot see why this is not a good idea. Is this routine, acceptable or a totally stupid idea for reasons i dont understand?
Conor Posted October 9, 2024 Posted October 9, 2024 Bigger holes and 25mm conduit. Anything smaller and it's a pain pulling the pipe through. Did it in several places. 1
JohnMo Posted October 9, 2024 Posted October 9, 2024 I wouldn't go through any block work, only doorways.
Super_Paulie Posted October 9, 2024 Posted October 9, 2024 yeah i just drilled 2x25mm holes through the cavity, lined them with 22mm conduit and passed the pipes though. Works without issue. Wasnt easy to get the return leg back through though as obviously you need to feed the entire remaining length back through the hole. I took a rough measurement of what distance i had remaining and cut it, fed it through and added significant swearing.
Post and beam Posted October 9, 2024 Author Posted October 9, 2024 4 hours ago, JohnMo said: I wouldn't go through any block work Whats the concern?
joe90 Posted October 9, 2024 Posted October 9, 2024 6 hours ago, JohnMo said: I wouldn't go through any block work, only doorways. I went through internal walls using 25mm overflow pipe rather than crowd too many pipes in doorways, it saved pipe and easier to do.
JohnMo Posted October 10, 2024 Posted October 10, 2024 10 hours ago, Post and beam said: Whats the concern? Don't think it looks tidy. Don't like taking pipes under non structural walls either. All my pipes went through doorways.
joe90 Posted October 10, 2024 Posted October 10, 2024 12 minutes ago, JohnMo said: Don't think it looks tidy. Don't like taking pipes under non structural walls either. All my pipes went through doorways. But it’s buried in screed 🤷♂️ 1
Barnboy Posted October 13, 2024 Posted October 13, 2024 I've just finished laying my ufh heating pipes, I've done the same as mentioned above. I drilled a 25mm hole in the dwarf block beneath my studwork, fed a length of 25mm flexi electrical conduit through and then slid my pipe through. The pipe has metres measure markings on it so I read the length of the feed leg before cutting that length and a tad more extra from the remaining reel once the room had been laid, fed this through the return conduit and to the manifold. I still have 2 loops running through the utility doorway, if I'd have put all my loops through the doorway then they would have all been touching, if they'd have even fitted. I think it all looks neat and tidy and will be hidden in a week anyway once the screed is down.
