Good afternoon, please provide some
help If you can.
We have just fitted a large top hung Ali Window and originally packed toe heel
but when pulling the window closed it
was not drawing in top left corner, so wasn’t shutting square.
So after reading a few forums where people advised to only pack at the bottom and side which we have now done, it’s sorted out one problem which is the gap is equal all round but not fixed the issue of closing accurately in top left corner ie square.
please help we have currently packed 100mm from top, on the sides & 100mm from each edge on the bottom, handle edge.
window is 1000mm wide x 1200mm deep.
any advise ???
