KirstyJ Posted September 14 Share Posted September 14 Good afternoon, please provide some help If you can. We have just fitted a large top hung Ali Window and originally packed toe heel but when pulling the window closed it was not drawing in top left corner, so wasn’t shutting square. So after reading a few forums where people advised to only pack at the bottom and side which we have now done, it’s sorted out one problem which is the gap is equal all round but not fixed the issue of closing accurately in top left corner ie square. please help we have currently packed 100mm from top, on the sides & 100mm from each edge on the bottom, handle edge. window is 1000mm wide x 1200mm deep. any advise ??? Link to comment Share on other sites More sharing options...
Russell griffiths Posted September 14 Share Posted September 14 Do you mean packed the frame in the brick work, or packed the glass in the frame. 1 Link to comment Share on other sites More sharing options...
KirstyJ Posted September 14 Author Share Posted September 14 Packed the glass in the frame Link to comment Share on other sites More sharing options...
joe90 Posted September 14 Share Posted September 14 It sounds like the frame is out of square although you may be able to adjust the hinges to allow square closure. Link to comment Share on other sites More sharing options...
