Gaz1892a Posted September 14 Author Share Posted September 14 Thanks for the reply guys, Is there a special tape for taping it? Good tip with the 100 and 50, makes life easier 🙂 What about the weep vents below DPC in the engineering bricks? Link to comment Share on other sites More sharing options...
Chanmenie Posted September 14 Share Posted September 14 17 minutes ago, Gaz1892a said: Thanks for the reply guys, Is there a special tape for taping it? Good tip with the 100 and 50, makes life easier 🙂 What about the weep vents below DPC in the engineering bricks? Foil tape https://www.toolstation.com/aluminium-foil-tape/p81953 1 Link to comment Share on other sites More sharing options...
saveasteading Posted September 14 Share Posted September 14 8 hours ago, G and J said: Just looked that up. Is it just for the ends of PIR sheets Me too. For all 4 sides. £3/m, so for a 2.4 x 0.6 board, add £18. = £1.20/m2. The site I found doesn't show the tech info esp u value. Clever. It wouldn't do for wonky old rafters though. Link to comment Share on other sites More sharing options...
G and J Posted September 14 Share Posted September 14 So does gapotape then expand to fill any gaps round the PIR? Link to comment Share on other sites More sharing options...
saveasteading Posted September 15 Share Posted September 15 10 hours ago, G and J said: does gapotape then expand Ig looks to me that it is soft foam, so it squeezes inoto place. Between rafters, better than expanding foam. No need under floors except maybe on the final board cut. Link to comment Share on other sites More sharing options...
G and J Posted September 15 Share Posted September 15 44 minutes ago, saveasteading said: Ig looks to me that it is soft foam, so it squeezes inoto place. Between rafters, better than expanding foam. No need under floors except maybe on the final board cut. So it’s ‘squeeze-o-tape’. Invented by Wallace one assumes! Link to comment Share on other sites More sharing options...
Dave Jones Posted September 15 Share Posted September 15 23 hours ago, G and J said: Just looked that up. Is it just for the ends of PIR sheets? it gives an interference airtight fit as timber is rarely dead straight. Link to comment Share on other sites More sharing options...
G and J Posted September 15 Share Posted September 15 So, a sheet of 140mm PIR costs about £53. Gapotape to line it costs £36. Ouch. That means I’ll spend about £2.5k on gapotape on our build on just the walls. That’s a lot of Smarties. I think I need to research alternatives, I’ll start a new thread if I can’t find it covered elsewhere. Link to comment Share on other sites More sharing options...
saveasteading Posted September 15 Share Posted September 15 Our solution was twofold. Nb this is for 100 year old rafters, so much twisted. 1. Instead of 100mm pir , use 2 x 50mm. That way it is easier to press them in. 2. After the first 50mm in in place, instead use mineral wool. It fits of course, and covers all the perimeter gaps. Obv the wool isn't such good insulation, but the figures are OK, and the practicality makes up for it. 1 Link to comment Share on other sites More sharing options...
