Been wracking my brains on how to pipe this waste. Have a dishwasher between the sink and the stack. I want to use a standpipe for the dishwasher rather than the little appliance spigots.
I only ever see the standpipes on the end of a run (probably for a reason). I understand I can't put a trap 'in series' with the sink, as the two will pull on each other.
Can I do the below, having the standpipe on a parallel branch, then 'tees' (or more to point, Y and 45deg) into the main branch just before the stack?
length of main branch is ~1.5m. The Y would be about 0.5m from the stack
Edited by OwenF
added lengths
Why aren't you putting the dishwater waste in to the sink trap? You can go a couple of metres with the outlet hoses.
See above, don't want to use the appliance spigots on the sink trap. Reason: 1) want to avoid messy hoses in sink cupboard and 2) want to mitigate gurgling noise associated with them
