We're having an ASHP installed. There will be an external isolator next to the unit, fed on its own circuit from the CU.
Quick question: is it acceptable to use T+E cable through the external wall and in to the rear entry of the isolator?
Or does this call for SWA?
T&e is fine if not exposed, i.e straight through the wall into the isolator.  Flexible conduit is often a better option from the isolator to the ASHP rather than SWA.
That bit will be up to the ASHP installer.
But I guess you could use conduit over the T+E if for any reason going straight in to the back of the isolator didn't work?
As usual, once I started looking properly at the situation my plan fell apart. I'm going to have to have a run of cable outside the house, coming up to the underside of the isolator. It's either that or rip open a tiled wall!
So I guess the choice is SWA vs T+E in conduit? The former is maybe better but requires a junction box.
