The Dude Posted August 8, 2024 Posted August 8, 2024 I have existing guttering draining into what appears to be dedicated rainwater drains (if I put a hose down the drain and turn it on I can see water flowing under manhole cover. If I run taps or flush toilets then nothing) Can I drain water from new extension into these? They do not appear to be dual use and it would save me the grief of a soakaway in a heavy clay area.
The Dude Posted August 9, 2024 Author Posted August 9, 2024 1 hour ago, Andehh said: The new extensions guttering or foul/waste water? This would be rain water only.
DevilDamo Posted August 10, 2024 Posted August 10, 2024 On 08/08/2024 at 12:14, The Dude said: heavy clay area. A soakaway wouldn’t work anyway.
Mr Punter Posted August 10, 2024 Posted August 10, 2024 You can run surface water into surface water drains and foul water into foul water sewers. What are you draining from the extension?
The Dude Posted August 12, 2024 Author Posted August 12, 2024 A soakaway would not work - we piled to 8m and were still bringing up clay. I explained this to building regs but they didn't want to listen. In any case it looks like I have surface water drains for rainwater from extension so am good.
