Montana 3827 Posted August 6, 2024 Posted August 6, 2024 My husband and I are renovating a 1930’s house that we recently purchased. After removing the floorboards from the suspended floor we discovered there are damp patches in the ground underneath (please see photos included). There are no visible leaks and it has not rained recently. It appears to be coming up from the rear of the property. We’ve just had the drains checked and it was determined they are working properly. The underfloor is clean, air bricks are clear and well-ventilated. The damp doesn’t seem to go past the DPC as the bricks above it are all dry. My question is, is this something to be concerned about and does anyone have an idea what the cause of this could be? We are planning on insulating between the joists under the finished floor and want to get this issue dealt with (if intervention is necessary) before installing it. Any input is appreciated.
Super_Paulie Posted August 7, 2024 Posted August 7, 2024 Is this not just ground moisture? Underneath the sub floor in my 1930s was always a bit damp/patchy around the outskirts, especially after rain. I just added as many air bricks as I could in the new extension and made sure the old ones were clear/replaced as they were just jammed with 100 years of crap. Once I had a howling gale under there I added my insulation and sealed the entire thing up.
Redbeard Posted August 7, 2024 Posted August 7, 2024 Even if the drainage is functioning OK is there anything about the 'lie of the land' which is directing water towards those walls? (In one case the damp only seems to come in just inside the wall). Can it be 'encouraged away' by 'softening', re-directing, French drain? You might also consider this as bed-time reading (go to bed very early, though!): https://assets.publishing.service.gov.uk/media/5f05d211d3bf7f2be6e0217a/suspended-timber-floors-underfloor-insulation-best-practice.pdf If you can tick all the 'boxes' in that guide you are probably a long way towards being OK.
ProDave Posted August 7, 2024 Posted August 7, 2024 There is unlikely to be any damp proof membrane under the concrete of that sub floor, so it is probably just ground water. That is why under floor ventilation of that type of floor is so important, so check carefully all the air bricks are free, not blocked, and most importantly, not covered by external ground level that has been raised too high and is blocking them. 1
saveasteading Posted August 7, 2024 Posted August 7, 2024 All the above. And then it is OK to spread a dpm over the whole area. It will stop evaporation and dampness into the void. 1 hour ago, ProDave said: not covered by external ground level that has been raised Shpuld not even be close. Keep 50mm min below the air bricks and dpm. It is a common issue that the ground level rises over decades, (leaves and muck ) even without paving being added.
Hughgo12 Posted August 8, 2024 Posted August 8, 2024 21 hours ago, saveasteading said: All the above. And then it is OK to spread a dpm over the whole area. It will stop evaporation and dampness into the void. Shpuld not even be close. Keep 50mm min below the air bricks and dpm. It is a common issue that the ground level rises over decades, (leaves and muck ) even without paving being added. Would that not bring the risk that moisture builds up, tracks along the DPM and up the wall?
saveasteading Posted August 8, 2024 Posted August 8, 2024 2 hours ago, Hughgo12 said: moisture builds up, tracks along the DPM and up the wall? I doubt it. The moisture is already there in the ground. It should permeate downwards and away unless there is another source. It's debatable though. If there is a healthy draught through the void it will clear the air, and chill the floor above it.
