Hannah77 Posted August 5, 2024 Share Posted August 5, 2024 Hi, New to building timber frames! I am installing load bearing walls over several stories. The c/c of the studs are 400mm at ground level and increase to 600mm c/c for the floor above as the loads decrease. However the cladding system is render board on battens and counter battens. The render board system and the breather membrane both need battens at 400mm c/c. This means that they can fix vertically to the external wall at ground directly into the studs. But at 1st floor they will only align every second stud with two battens in between missing the studs entirely. The wall build up is just 9mm OSB on the outside face for racking. What do you do for the 600mm c/c studs? The battens need to be fixed back to studs and not OSB as the fixing strength will be insufficient for the wind loads and self weight of the cladding. Cheers Hannah Link to comment Share on other sites More sharing options...
Mr Punter Posted August 5, 2024 Share Posted August 5, 2024 I think 400 centres would be far better. It really will not be much more material, as often there will be additional studs around openings. Which battens are being fixed first, vertical or horizontal? Link to comment Share on other sites More sharing options...
Hannah77 Posted August 5, 2024 Author Share Posted August 5, 2024 Thanks @Mr Punter 4 minutes ago, Mr Punter said: Which battens are being fixed first, vertical or horizontal? The membrane requires vertical battens first to allow for moisture to drain down face. Link to comment Share on other sites More sharing options...
Mr Punter Posted August 5, 2024 Share Posted August 5, 2024 What is the point of the horizontal battens? 1 Link to comment Share on other sites More sharing options...
Russell griffiths Posted August 5, 2024 Share Posted August 5, 2024 Stick to 400 spacing everywhere Link to comment Share on other sites More sharing options...
