Evening all.
I've built a single skin block work garden office using dense blocks. I plan to clad the outside in strip timber.
I am considering putting some sort of membrane around the walls before applying the cladding, just to ensure protection from the rain.  have seen different housewrap products online.
1. Is there a particular type of wrap anyone would recommend or avoid in these circumstances?
2. Is roofing underlay any good for the job?
Thanks
Basically you can use roof breathable membrane on either wall or roof, but you can only wall breathable membrane for walls (not suitable for a roof). Wall specific is a lower spec overall.
38 minutes ago, Tony K said:
roofing underlay
You need to be specific here, are you talking breathable or non-breathable?
Well, my presumption is breathable, but I'm open to advice!
From what you say, a breathable roof membrane will do a fine job on my walls?
I've done exactly this with my shipping container, used VP300 roofing underlay, for roof and sides to keep water off the external insulation.
On to the next question!
How best to pin the membrane in place before I fix horizontal batons over it? I've tried copper clout nails, staples, and various screws, but they all buckle against the dense blocks.
