Pocster Posted July 19, 2024 Posted July 19, 2024 I made SWMBO an automated irrigation system ; it works well . Currently I use a transparent tank outside so she can see when it’s low and fill it up . Don’t trust any HA device off the mains to fill the tank and one day fail . Problem is as the tanks transparent it’s not uv stable but it’s easy ( without going outside ) too see the water level is low and top it up . So I can’t use a transparent tank . A non transparent is fine but I can’t find a ‘simple’ mechanical device that shows the water level ( like a flag on a buoy ! ) . Trying to spend very little on this 😊 Any suggestions?
joe90 Posted July 19, 2024 Posted July 19, 2024 T a hose into the output (before any control ) and use a clear pipe vertical next to the tank (in the shade) and the water level will be seen within this pipe 🤷♂️ 1
Redbeard Posted July 19, 2024 Posted July 19, 2024 A piece of plastic pipe glued to a small ball and a clearance hole in the lid. You can even paint 'Full, half-full and empty' marks on it. Of course the clearance around the pipe means that ingress of 'foreign bodies' is not prevented. 1
ToughButterCup Posted July 19, 2024 Posted July 19, 2024 External clear pipe with diagonal lines painted behind the pipe. Shows the meniscus clearly 2
Pocster Posted July 19, 2024 Author Posted July 19, 2024 37 minutes ago, ToughButterCup said: meniscus That’s a big word . Doctor told me that’s what I excrete …
