Pocster Posted July 19, 2024 Share Posted July 19, 2024 I made SWMBO an automated irrigation system ; it works well . Currently I use a transparent tank outside so she can see when it’s low and fill it up . Don’t trust any HA device off the mains to fill the tank and one day fail . Problem is as the tanks transparent it’s not uv stable but it’s easy ( without going outside ) too see the water level is low and top it up . So I can’t use a transparent tank . A non transparent is fine but I can’t find a ‘simple’ mechanical device that shows the water level ( like a flag on a buoy ! ) . Trying to spend very little on this 😊 Any suggestions? Link to comment Share on other sites More sharing options...
joe90 Posted July 19, 2024 Share Posted July 19, 2024 T a hose into the output (before any control ) and use a clear pipe vertical next to the tank (in the shade) and the water level will be seen within this pipe 🤷♂️ 1 Link to comment Share on other sites More sharing options...
Redbeard Posted July 19, 2024 Share Posted July 19, 2024 A piece of plastic pipe glued to a small ball and a clearance hole in the lid. You can even paint 'Full, half-full and empty' marks on it. Of course the clearance around the pipe means that ingress of 'foreign bodies' is not prevented. 1 Link to comment Share on other sites More sharing options...
ToughButterCup Posted July 19, 2024 Share Posted July 19, 2024 External clear pipe with diagonal lines painted behind the pipe. Shows the meniscus clearly 2 Link to comment Share on other sites More sharing options...
Pocster Posted July 19, 2024 Author Share Posted July 19, 2024 37 minutes ago, ToughButterCup said: meniscus That’s a big word . Doctor told me that’s what I excrete … Link to comment Share on other sites More sharing options...
