I have got a pile of door linings of 32mm depth, with the words “nom 27mm” on them.
Are these suitable for hanging FD30 fire doors/meeting building regs? I know that I should be fitting 32mm linings, but not sure if that is 32mm nom or 27mm nom.
Thanks!
  • 1 year later...
Did you get an answer?
Such wood is sold with its pre-planed dimensions. After planing it is less, so 32mm becomes 27mm when you measure it.
3 hours ago, Omnibuswoman said:
Thanks - no I didn’t get an answer to this, so had filed it under “things to deal with later”. Very helpful to know.
Do the ones you have feature the rebate for the intumescent strips to be loaded into?
