RichS Posted October 24, 2017 Posted October 24, 2017 Simple question, does it matter which. Does one have any advantages over the other. For my ground floor layout I need approx 300m, (80m + 80m + 85m + 45m) and have found a source of one of the above in that sized roll. Most go from 200m - 500m.
Nickfromwales Posted October 24, 2017 Posted October 24, 2017 Pex al pex for me every time. Much much more robust plus it has memory, so when you manipulate / bend it, it stays there . Pert is ok if your in spreader plates I suppose but it has no attraction for me.
RichS Posted October 24, 2017 Author Posted October 24, 2017 11 minutes ago, Nickfromwales said: Pex al pex for me every time. Much much more robust plus it has memory, so when you manipulate / bend it, it stays there . Pert is ok if your in spreader plates I suppose but it has no attraction for me. Thanks Nick, right answer . That's the one I can buy a 300m roll of therefore leaving as little waste as possible.
Nickfromwales Posted October 24, 2017 Posted October 24, 2017 1 hour ago, RichS said: Thanks Nick, right answer . That's the one I can buy a 300m roll of therefore leaving as little waste as possible. You've never seen a 300m roll of UFH pipe have you Youll need a pipe decoiler or a friend with REALLY long arms
RichS Posted October 25, 2017 Author Posted October 25, 2017 16 hours ago, Nickfromwales said: You've never seen a 300m roll of UFH pipe have you Youll need a pipe decoiler or a friend with REALLY long arms Ah, right. So it's hire an orangutan or buy shorter rolls then
Nickfromwales Posted October 25, 2017 Posted October 25, 2017 I'd buy a 1x 150 and 2x 100. I've just done one at 120m and it's not a one man job. . 300m even I wouldn't attempt without the decoiler. 1
