DHW is heating some radiatosrs
Just had my ASHP system power flushed. The radiators on the system were all new when ASHP was installed 2 years ago but most of the copper piping is about 20 years old being used for oil fired central heating
 Today (1 daY AFTER FLUSH)with heating turned off as it has been since about May) several radiators (4)  are heating up to +- 30.
Any ideas - installer at a loss
Thanks
Graham
5 hours ago, graham1 said:
If it is a problem with 3 way valve would not all the radiators heat up not just 4 or 5
Need more facts, but if the valve, either diverter or 2 port, is letting by just a tiny bit, then the first few rads in the loop would get a bit warm.
The OP states they are getting to maybe 30C during DHW cycle, but the flow temp would typically be higher, which points to a little flow sleeping past. Possibly because the valve is damaged of maybe a little bit of crud from the power flush is stuck on the seat.
8 hours ago, sharpener said:
Installers seem to recommend ESBE valves for anything over about 5 kW.
That could be more to do with pressure drop than anything else. Normal diverter valves have quite large pressure drops, so when you start pumping more than about 1.5m3/h the drop is quite big, even with 28mm valves.
Thanks
Graham
Not sure how to respond to answers
  The  valve was in the manual position. Waiting to see result as set now
