July 4, 20242 yr Hi All, I've got a fair few wooden exterior painted garage/shed doors that have been adapted to fit with repairs additions and have been fully prepped with solvent primer & solvent Crown grey undercoat. The actual finshed colour looks pretty good as is. I've got a 5lt tin of Sadolin Exterior UV barrier Varnish going spare, so any reason why I should'nt just use this on top of the undercoat instead of buying a gloss topcoat ? Ed
July 4, 20242 yr 1 hour ago, Ed21 said: Hi All, I've got a fair few wooden exterior painted garage/shed doors that have been adapted to fit with repairs additions and have been fully prepped with solvent primer & solvent Crown grey undercoat. The actual finshed colour looks pretty good as is. I've got a 5lt tin of Sadolin Exterior UV barrier Varnish going spare, so any reason why I should'nt just use this on top of the undercoat instead of buying a gloss topcoat ? Ed No reason not to, as long as you don't get a reaction from the two.
July 5, 20242 yr Author 3 hours ago, Alan Ambrose said: Maybe try out a little bit to check it doesn’t look horrible? Yes I'll be doing a test piece and the product is all good branded stuff and solvent based, . I was more concenrtned about longevity and potential hassle when or if it needs a recoat later on.
July 5, 20242 yr Well as far as I can see they're both (as it happens): Resin: Alkyd. Solvent: Dearomatised White Spirit. So maybe ... otherwise you're doing a chemistry experiment.
July 5, 20242 yr I think if the appearance is going to be acceptable you will be OK, particularly if they are both based on the same resin polymers. Most of the covering power in a paint system is in the undercoat, it needs UV protection though which the varnish will provide. We had a continual problem with a damp stain bleeding through on a chimney breast. International Paints'(*) Stain Block was completely useless but two coats of Ronseal matt polyurethane fixed it and would take matt emulsion on top. * makers of the famed International Yacht Varnish which says on the tin "not suitable for exterior use".
July 19, 20242 yr I would've said not to bother, but yeh as one of the previous comments says give is a test before using it if you decide to
