Tile up to or under door frames?
Shanemac
Hi, sorry if this is a silly question but I can't seem to find a definitive answer. I'm about to start tiling and currently it's just the door linings in place, no architrave etc yet. Should the tiles be fitted up next to the door linings with a small expansion gap and then siliconed or should I cut the bottoms of the frames and slide the tiles underneath?
The latter would look better but isn't there the potential for the frame to drop if not supported from the floor as well as the screws into the walls?
Many thanks
