machtucker Posted June 26, 2024 Share Posted June 26, 2024 Hi everyone, I have a set of steps which I’ve had rendered with sand and cement. I have subsequently laid the Indian sandstone slabs. I have mortar at the front of each step which has spilled over a little onto the rendering. I’d like to be able to sand it flush with the render before touching up with primer and masonry paint. What is best to use to sand the mortar? Cheers, Ed Link to comment Share on other sites More sharing options...
SteamyTea Posted June 26, 2024 Share Posted June 26, 2024 Isn't there a chemical method that you can use? Link to comment Share on other sites More sharing options...
joe90 Posted June 26, 2024 Share Posted June 26, 2024 Brick acid. Link to comment Share on other sites More sharing options...
machtucker Posted June 26, 2024 Author Share Posted June 26, 2024 Ahh yes that may be an idea, although there maybe a mm or two in places. I will have a look when I get home. Link to comment Share on other sites More sharing options...
SteamyTea Posted June 26, 2024 Share Posted June 26, 2024 3 minutes ago, joe90 said: Brick acid. Noticed it is limestone. Acid may discolour it.. 1 Link to comment Share on other sites More sharing options...
joe90 Posted June 26, 2024 Share Posted June 26, 2024 An alkaline cleaner should always be used for any stains on limestone, and this includes cement residues. Care should be taken when choosing a cleaner, as many do contain acid. Find a cleaner like Lithofin Power Cleaner that eases cement removal and other stains from limestone without acid. Link to comment Share on other sites More sharing options...
