MariaD Posted June 20, 2024 Share Posted June 20, 2024 Hi everyone, I've contacted a guy who would do the site clearance for my site. He asked me if I was looking for certificates. What will be removed from the site are the following: Weeds Overgrown bushes (Gorse) Some rubbish Dirt A small asphalt patch. Which of these require certificates? Who can request them, and what’s the cost? Additionally, do I need planning permission to remove the asphalt patch (approximately 40-50 sqm)? Thank you so much for your attention. Link to comment Share on other sites More sharing options...
nod Posted June 20, 2024 Share Posted June 20, 2024 None 2 Link to comment Share on other sites More sharing options...
Alan Ambrose Posted June 20, 2024 Share Posted June 20, 2024 (edited) To go to a proper waste plant, the dirt would need to be tested if there’s any amount of it. (A single wheelbarrow full probably gets through the system unscathed.) There’s restrictions on knotweed etc. Look up ‘WAC testing’ (not some kind of sanity test). If it’s going to be left in a layby somewhere you won’t need any certs. Check he’s not being an idiot over one wheelbarrow worth, but suggest the answer is ‘yes’. Edited June 20, 2024 by Alan Ambrose 1 Link to comment Share on other sites More sharing options...
Blooda Posted June 20, 2024 Share Posted June 20, 2024 Just ensure he is licenced or using a licenced. We had around 40 odd grabber lorries full of muck away, made up ground, clay etc etc. didn't see a certificate, only collection dockets. but they were licenced so probably didn't end up in layby. Is the asphalt patch part of a bigger scheme, and are you planning to replace it with hard standing ? Link to comment Share on other sites More sharing options...
MariaD Posted June 20, 2024 Author Share Posted June 20, 2024 (edited) 5 hours ago, Blooda said: Just ensure he is licenced or using a licenced. We had around 40 odd grabber lorries full of muck away, made up ground, clay etc etc. didn't see a certificate, only collection dockets. but they were licenced so probably didn't end up in layby. Is the asphalt patch part of a bigger scheme, and are you planning to replace it with hard standing ? Thanks for the answer. No, the asphalt patch is not part of a bigger scheme. Once removed, I want just grass growing. How do I check that he is licensed? Edited June 20, 2024 by MariaD Link to comment Share on other sites More sharing options...
Blooda Posted June 21, 2024 Share Posted June 21, 2024 12 hours ago, MariaD said: Thanks for the answer. No, the asphalt patch is not part of a bigger scheme. Once removed, I want just grass growing. How do I check that he is licensed? Sometimes hard to find in the database. Waste Carriers, Brokers and Dealers (data.gov.uk) 1 Link to comment Share on other sites More sharing options...
mjc55 Posted July 6, 2024 Share Posted July 6, 2024 Don't know what the CIL situation where you are doing this work, but make sure that everything is in place if there is a CIL regime, could be costly otherwise. Link to comment Share on other sites More sharing options...
MariaD Posted July 11, 2024 Author Share Posted July 11, 2024 On 06/07/2024 at 10:52, mjc55 said: Don't know what the CIL situation where you are doing this work, but make sure that everything is in place if there is a CIL regime, could be costly otherwise. Hi, thanks for replying. Could you please explain to me what CIL is? Link to comment Share on other sites More sharing options...
mjc55 Posted July 11, 2024 Share Posted July 11, 2024 (edited) Community Infrastructure Levy. It's a "tax" on building a new house. Doesn't apply to all local authorities, so the first thing to do is to check your local situation. If it is in place then it is based on the purchase price of your plot (at least it is in Dorset). The key thing is that if there is a CIL in place that you DO NOT start any work before claiming self-build exemption. This is key, get things wrong and you will be liable no matter what. Just noticed you are in Republic of Ireland, I am guessing that this is not really applicable to you as it is an UK thing. Edited July 11, 2024 by mjc55 Link to comment Share on other sites More sharing options...
