Spadez88 Posted June 19, 2024 Posted June 19, 2024 Hello, We're looking to put an offer on a house but there are cracks in the front elevation of the first floor and honestly I can't work out if tis a problem or not. If we proceed we know we need to get a structural engineer in, but before potentially wasting the sellers time with an offer that we may then retract, we're trying to just educate ourselves a little first. Is this crack a sign of a serious issue, or typical for a property of this age? Any insight appreciated. James
joe90 Posted June 19, 2024 Posted June 19, 2024 That appears to be bay windows which are prone to cracking away from the main walls but extends top left into the main wall, someone has pointed a bit of the crack and not sure how much further it extends. You really need to get it seen by a structural engineer IMO.
Conor Posted June 19, 2024 Posted June 19, 2024 How does the gable wall look? And why is there scaffolding up?
Spadez88 Posted June 19, 2024 Author Posted June 19, 2024 Hello, Thank you for the replies. The scaffolding is up because of a separate water ingress on that wall apparently. From what I can see of the gable wall it looks ok although it is covered in paint. Google street view suggests these cracks were not there in 2020.
Roundtuit Posted June 19, 2024 Posted June 19, 2024 Have a look at other houses in the street to see if they've suffered any settlement perhaps. Historic settlement would have happened in the first few years I imagine. Is the water ingress linked maybe? Leaking gutters or downpipes affecting the foundations? That would explain more recent movement. Definitely a professional opinion required.
