Munaf sadulla Posted June 19 Share Posted June 19 Hi if anyone help me with vent-axia issue regarding boost. when i am having shower, Boost doesn’t kick in. It was working fine before. Since i made some changes in settings, it’s not working properly like before. Can you please guide me if anyone knows regarding this? Is it something to do with Humidity sensor or some settings? Thanks munaf Link to comment Share on other sites More sharing options...
BotusBuild Posted June 19 Share Posted June 19 Munaf, I think you have the answer in your question - you made some changes in settings. I suggest revisiting the settings and revert to what you had before (I hope you remember what they were), and check if the boost kicks in at the next shower time. If the boost doesn't kick in, then maybe the humidistat is faulty. 1 Link to comment Share on other sites More sharing options...
JohnMo Posted June 19 Share Posted June 19 Ours hardly ever kicks in, it did the first year after the build, but now everything has dried out, it doesn't need to. Our boost kicks in around 60%, if it doesn't get there it doesn't boost. As the weather changes so does the humidity inside and out. 1 Link to comment Share on other sites More sharing options...
Conor Posted June 19 Share Posted June 19 (edited) Reset to factory settings. Edited June 19 by Conor 1 Link to comment Share on other sites More sharing options...
