cbk Posted June 17, 2024 Posted June 17, 2024 Hi, I’ve ended up with 3 part coils of UFH pipe and wondered if I could use it instead of MDPE pipe to distribute rainwater from my harvesting tank around the garden.
Mike Posted June 17, 2024 Posted June 17, 2024 If I recall corrrectly, UFCH pipe generally needs to be protected from UV light, so I wouldn't expect it to last long in a garden. Unless, perhaps, you plan to bury it.
JohnMo Posted June 17, 2024 Posted June 17, 2024 19 minutes ago, cbk said: Hi, I’ve ended up with 3 part coils of UFH pipe and wondered if I could use it instead of MDPE pipe to distribute rainwater from my harvesting tank around the garden. Really depends on spec PEX based UFH pipe isn't UV stable, however pert-al-pert is. So just depends on the pipe you've used. If it's underground it should be ok, not so sure how frost tolerant it is however.
cbk Posted June 17, 2024 Author Posted June 17, 2024 I was planning to bury so UV may not be an issue, but not very deep so frost might be an issue. Also not sure which type I have as was left behind by plumbers. Is there an easy way to tell PEX from pert-al-pert pipe? Also can you get pipe fittings to join to MDPE for above ground sections with taps etc,
