Grannysan Posted June 11, 2024 Posted June 11, 2024 Hi. Can anyone tell me if it's possible to change the time that the Legionella cycle runs on my cylinder? And if so, how to do it - simply explained for technically-challenged me, lol. Just had ASHP & solar installed & it would be better if it ran during the day, when we have solar input plus half-price electricity. (It's currently running on a Friday evening peak time when our electricity price is doubled.)
JohnMo Posted June 11, 2024 Posted June 11, 2024 You need to step back slightly and ask the question do I need it at all. If you use a good proportion of the water each day and don't have infirmed elderly people in the house there is a good chance you don't. This is a good write up on the subject https://www.heatgeek.com/hot-water-temperature-scalding-and-legionella/ Other than that tell the installer to get his arse back to change the timings. Or talk you through it. Every heat pump will have a different way to change the timings.
Redbeard Posted June 11, 2024 Posted June 11, 2024 My understanding is that Legionella cycles (to 70ish degrees) are generally set for about 3 a.m. - ish - to reduce the risk of scalding. In terms of asking questions, I suppose one would be 'is there anyone likely to use the hot tap - in the middle of the day - who is not aware of the Legionalla cycle at x o'clock on y-day?'.
joe90 Posted June 11, 2024 Posted June 11, 2024 I too don’t believe a legionella cycle is required in a domestic situation (I certainly didn’t have one on my build) if I did I would have a temp controller mixer before any outlets.
Grannysan Posted June 11, 2024 Author Posted June 11, 2024 3 hours ago, Grannysan said: Hi. Can anyone tell me if it's possible to change the time that the Legionella cycle runs on my cylinder? And if so, how to do it - simply explained for technically-challenged me, lol. Just had ASHP & solar installed & it would be better if it ran during the day, when we have solar input plus half-price electricity. (It's currently running on a Friday evening peak time when our electricity price is doubled.) EDIT: We are both elderly & I am immunocompromised - so yes, I'd feel safer with the Legionella cycle ON, especially as we tend not to use a lot of hot water. Just would like to change the time when the cycle kicks in - if anyone can help with instructions for changing that.
JohnMo Posted June 11, 2024 Posted June 11, 2024 3 minutes ago, Grannysan said: We are both elderly & I am immunocompromised - so yes, I'd feel safer with the Legionella cycle ON, especially as we tend not to use a lot of hot water. Just would like to change the time when the cycle kicks in - if anyone can help with instructions for changing that So what you need to provide is ASHP make and model, then someone will know the answer.
Grannysan Posted June 17, 2024 Author Posted June 17, 2024 On 11/06/2024 at 19:53, Grannysan said: EDIT: Make is Samsung. Model No is AE160RXYDEG. Still hoping for help...
Andeh Posted June 17, 2024 Posted June 17, 2024 We turned ours off! If we wee to have elderly at risk, I'd manually zap it with the immersion I guess!
sharpener Posted June 18, 2024 Posted June 18, 2024 (edited) Installation instructions are here, I can't find any mention of legionella settings. Found a more comprehensive manual here, periodical disinfection of HW tank settings are described on p 141. HTH Edited June 18, 2024 by sharpener
