BotusBuild Posted June 5, 2024 Posted June 5, 2024 I know that as part of an electrical safety check (in order to get an EICR) that our consumer unit will be checked. See pictures. Can a qualified electrician here tell me if this is likely to need to be changed?
garrymartin Posted June 5, 2024 Posted June 5, 2024 It really depends on the inspector and the reason for the EICR as to how they will code it. Â As a layman, at the minimum, I would expect a C2 (potentially dangerous) in relation to the lack of an RCD and the reasonable expectation that sockets (especially given one of the ways is marked as garage extension sockets) could power equipment outdoors. If you have a very generous inspector, you might get C3 (improvement recommended) for anything else, but it depends on a lot of variables that won't be visible just from the photos you've provided. Â Just because the consumer unit is old and may not meet current standards doesn't mean that it automatically has to be replaced.
ProDave Posted June 5, 2024 Posted June 5, 2024 Yes get a new CU that is very old (1965?) and as pointed out no RCD protection and no hope of getting RCBO's to upgrade it. Once cable witn no sleeving on CPC but that is trivial to fix.  Likely no earth bonding to water or gas.  Third MCB from main switch seems to feed a lot of different stuff.
BotusBuild Posted June 5, 2024 Author Posted June 5, 2024 1 hour ago, garrymartin said: one of the ways is marked as garage extension sockets That will be removed  2 hours ago, ProDave said: CU that is very old (1965?) No older than late 1980's 2 hours ago, ProDave said: Likely no earth bonding to water or gas. There is 😀 2 hours ago, ProDave said: Third MCB from main switch seems to feed a lot of different stuff. Basically sockets in one side of the house. There is another MCB for the other side. It could be labled simply " sockets, right hand side"Â
Mattg4321 Posted June 5, 2024 Posted June 5, 2024 Not a big job, so just get it changed for one with SPD and RCBO’s
BotusBuild Posted June 6, 2024 Author Posted June 6, 2024 14 hours ago, Mattg4321 said: Not a big job 🤣🤣🤣🤣🤣🤣 Then why am I being quoted £600 or more??
ProDave Posted June 6, 2024 Posted June 6, 2024 3 hours ago, BotusBuild said: 🤣🤣🤣🤣🤣🤣 Then why am I being quoted £600 or more?? CU with SPD's is likely to cost in the region of £200 Full days job to change it and test everything properly so £300 would be about normal.  So £600 is not extortionate.
BotusBuild Posted June 6, 2024 Author Posted June 6, 2024 🙂 so it is a big job ( in my eyes at least)
Mattg4321 Posted June 6, 2024 Posted June 6, 2024 A single days job can hardly be called ‘big’. I guess it’s subjective though.Â
