I've got turn limiter listed under the accessories hardware section of each window on my Internorm order.  Does anyone know if this is the same as an opening restrictor?  Thanks
So this is the kind of thing meant to be set by the fitter to stop them hitting walls etc rather than an adjustable child restrictor if you know what I mean?  Does Internorm do child restrictors?  I'm guessing this is another thing I should've specified when ordering.  Doesn't seem very safe to have these opening that far in kids upstairs bedrooms.
Do you know if there are any retrofit options on adjustable child restrictors? Thanks
Yes
Standard restrictors work but I can’t guarantee that the supplier will know how to fix them.
They may say they don’t work but they do, they just need to understand what screw to remove on the mechanism and location. Which determines the finger restrictor position.
I prefer side fixing but they can be fixed on the bottom.
Edited by craig
If they are tilt and turn (inward opening) then the answer is no. Can't speak for casement. I've come up with my own high tech solution....a white doorstop screwed to the window board to stop the window opening more than the depth of the reveal 🤣
In an emergency, easy to force open.
Edited by Conor
13 hours ago, craig said:
Yes
Thanks Craig, that looks like a good solution.  I'm not sure I'm going to be able to work that out but I will see if the fitters know where it is.
My fitters have offered to retrofit the Internorm child restrictor which I think is called a 'turn lock restrictor', and when the Allen key is turned it only opens on the tilt (see pics).  Is it wise to retrofit these, including to windows with integrated blinds?  They say they have retrofitted them before.
Yes they can be retrofitted, you’ll lose the key. The fixing point is using the screw that holds the mechanism to the sash, you have a couple but generally only one supplies to space for it to work due to mushroom pin/keep locations. You can only use one screw (see above pic).
I tend to cut the head of a screw put it in the other screw hole and fix with gorilla glue.
The actual restrictor will fix into place easy enough.
This option would be the easier and most cost effective option, as you can this yourself. A couple of quid per restrictor, then your time.
Check warranty scenario though. We wouldn’t have any issue with you doing this but others might.
 We have one of these on our newly fitted T&T internorm windows - specified when bought.  We had to fit it for Building Regs - needed it opened fully for Part O but not opening for Part K.
And so my Internorm window saga continues... As a goodwill gesture the window company I used have agreed to retrofit restrictors.  They gave me the option of turn lock or concealed.  I opted for the concealed ones.  They are claiming they are getting these directly from Internorm and hence will have a long lead time.  @craig is it definitely the case that Internorm do not sell concealed restrictors?
They are referring to the turn lock, not a restrictor. You can have a concealed or visible turn lock supplied by Internorm, an opening restrictor as mentioned above, would be an after-market solution and unlikely to be something the supplier or Internorm supported.
You can get left and right options on Amazon, they're about £5 per restrictor and something you could do yourself.
Concealed turn lock (it's not concealed but flush mounted) this is from a different supplier of course.
Child finger restrictor
The picture below shows the space available from the restrictor to the locking keep, you'd be able to judge easily if it fitted in place or not.
Restrictor arm in the closed position.
Edited by craig
This is the concealed restrictor I'm being offered.  Isn't this a third party one?  I'm not opposed to them fitting third party, I did request this so it could be resolved quickly.  But they are telling me they are getting these ones directly from Internorm and say there will be long lead time.
Interesting, I need to look into that - not aware of that (you learn something every day), not sure how it works tbh.
Edited by craig
Supplier has just got back to me.  It is Internorm.  Called a 'rebate stag guiding rail'.  See image.
  • 1 year later...
I am also looking into this with Internorm tilt and turn windows - fitter was not FENSA registered and we need retrospective building regs certificate. But also it is kind of scary doing DIY near such a big low window. Building Regs K2 I think means restricting to opening 100mm max for our 2 low windows (I haven't spoken to building control just yet).
Guarding is the typical norm, it had to be non-climbable (vertical rails) or glass panel and can be internal or external but both will look awful on our period house.
The alternative is a window restrictor but only the ones meeting specific BS standards for force are allowed and it has to be keyless and permanent I believe, so it can't be left unrestructed, plus you need toughened glass. This is in BCA technical guidance note 1 from the Building Control Alliance for:
Window openings in external walls with cill heights between 300mm & 800mm above finished floor level.
A few of these window restrictors have a two-handed way to open the window further in order to use as a fire escape - Angel WOCD is one I've seen mentioned - but can internorm timber/alu have their sashes removed? The R02 egress window restrictor says its building regs approved. Jackloc permanent cable restrictor might be strong enough? I would really like something that doesn't need drilling into the frame.
We have a GF window we'd prefer to only open one way so I'm also interested in a turn restrictor. The integrated ones show in @craig's photos is shown in internorm brochures as suitable for care homes (not sure on building control)o'
It’s not uncommon for these to be put in for inspection and completion, eg for the house to be ‘signed off’, and then burglars break in a week later and steal them, but sometimes the owners have a very poor memory and forget to buy new ones to replace the ones that went missing. 👀
You can use a simpler method. All the integrated one is doing, is effectively turning a stopper to prevent the window going into the turn position and allowing tilt only.
a simpler method is using a screw at the relevant point on the mushroom pin, preventing the pin going in the direction of turn/tilt.
