Onoff Posted April 13 Share Posted April 13 This ref the "rubbers" that seal 2G units on an internally glazed door. I've changed the 28mm units from patterned to clear glass made up by a local place. To measure up I hooked out the rubbers, removed the internal plastic beads with a paint scraper and measured the glass. I then refitted the glass, refitted the beads inside and lastly, refitted the rubbers which tbh was a pita. The new units made, I again hook out the rubbers, then take out the internal beads. New unit fitted and trims in, rubbers last. What a pig, ten times worse than when I first did it! I've made a hash of if and in places the rubbers are irretrievably distorted. When I removed / refitted the second time the ambient temperature was warmer. I even used some silicone spray to help ease things in and worked my way along pushing the rubbers in with a screwdriver. New rubbers are the only option. What did I do wrong? I'm also having trouble matching the profile despite having ordered a sample pack off eBay: Link to comment Share on other sites More sharing options...
dpmiller Posted April 13 Share Posted April 13 so is it likely your spray lubricant has swollen the rubber? Link to comment Share on other sites More sharing options...
Onoff Posted April 13 Author Share Posted April 13 2 hours ago, dpmiller said: so is it likely your spray lubricant has swollen the rubber? Dunno, someone else said don't take the rubbers out! So I took the windows out, clipped the rubbers back in, put the units in and banged the trims on with a rubber mallet. All good. Link to comment Share on other sites More sharing options...
