Evening,
Using Acad 2010:
I can't remember the command...
I've drawn a complex shape in 2D. I want to turn it into a polyline, nothing I haven't done a thousand times before. So I enter PEDIT, then use JOIN. Not having it, must be a gap.
There is a command that lets you click and sort of plots around the shape so you can see where the gap is?
Name escapes me!
Anyone?
Cheers
Just click on the line it will show the nodes and then you can investigate each one, if you move a node and one line stays still there is your gap but IIRC you can close a shape with straight lines or curves and set a gap tolerance to close.
Done it. I think it was because I'd originally drawn in Draftsight. I saved to Dropbox then opened it up in AutoCAD.
I redrew over the shape then used PEDIT.
