alayton Posted March 25, 2024 Posted March 25, 2024 Do I need a breathable membrane over my ICF as seems to be suggested for cavity wall when cladding....I will be using Cedral Click.
BotusBuild Posted March 25, 2024 Posted March 25, 2024 Simple answer, yes. It shows this on their website
FM2015 Posted March 26, 2024 Posted March 26, 2024 On 25/03/2024 at 13:23, BotusBuild said: Simple answer, yes. It shows this on their website For icf application?
FM2015 Posted March 26, 2024 Posted March 26, 2024 On 25/03/2024 at 12:54, alayton said: Do I need a breathable membrane over my ICF as seems to be suggested for cavity wall when cladding....I will be using Cedral Click. Three people to consult. 1. ICF manufacturer 2. Building control/warranty provider 3. Cladding manufacturer specifically with regard to ICF. Potentially not in that order.
SteamyTea Posted March 27, 2024 Posted March 27, 2024 Seems strange that a breather membrane would be needed, as that is to control vapour getting out, but to stop liquid water getting in. You may find that a water screen of some sort is needed between the ICF and the cladding and a breathe membrane is the easiest and most familiar.
BotusBuild Posted March 27, 2024 Posted March 27, 2024 13 hours ago, FM2015 said: Three people to consult. 1. ICF manufacturer FYI - if it is Nudura, they will only "warrant" the use of Dryvit. Both companies ultimately owned by the same group.
FM2015 Posted March 27, 2024 Posted March 27, 2024 8 hours ago, BotusBuild said: FYI - if it is Nudura, they will only "warrant" the use of Dryvit. Both companies ultimately owned by the same group. Dryvit is a render system rather than cladding??. There is a lot of cross selling with "do it our way or else" flying around. Hence why I suggested warranty provider and cladding manufacturer as points of contact. Neither are selling something the OP hasn't the intention of buying.
BotusBuild Posted March 27, 2024 Posted March 27, 2024 2 minutes ago, FM2015 said: Hence why I suggested warranty provider and cladding manufacturer as points of contact. Neither are selling something the OP hasn't the intention of buying. Totally agree with POV. 1
