PeterW Posted October 4, 2017 Posted October 4, 2017 Quick question... What is under the bath and behind the bath panel classed as by way of zones..? need to find a location for an LED transformer and it makes the most sense to put it under the bath but I’m not sure if that’s possible ..?
Onoff Posted October 5, 2017 Posted October 5, 2017 Zone 1, think of say a freestanding bath. But if you make it so you need a "tool" to get under there then it's outside the zone rule. Screwdriver to dig mastic/unscrew panel etc. Even a thin "blade" to lever off a magnetic catch panel.
Nickfromwales Posted October 5, 2017 Posted October 5, 2017 7 hours ago, PeterW said: Quick question... What is under the bath and behind the bath panel classed as by way of zones..? need to find a location for an LED transformer and it makes the most sense to put it under the bath but I’m not sure if that’s possible ..? Put it in an IP enclosure. Think of a Jacuzzi bath with the gear underneath.
Onoff Posted October 5, 2017 Posted October 5, 2017 10 minutes ago, Nickfromwales said: Put it in an IP enclosure. Think of a Jacuzzi bath with the gear underneath. Didn't I propose doing this in my mega bath thread, for my LED driver? Even I can't remember! Of course I've now put the driver outside the bathroom. Just make sure everything's bottom entry...
PeterW Posted October 5, 2017 Author Posted October 5, 2017 Perfect ..! I was thinking there is a rule about having to use a tool that it is exempt. Will use a box anyway
