leemkule Posted March 12, 2024 Share Posted March 12, 2024 This is probably a silly question, but please bare with me. If a 32mm basin waste maximum run is 1.7 meters, does that mean the entire pipe run from basin to larger waste pipe can be a maximum of 1.7 meters, or does it just mean a single part of the run can't exceed 1.7 meters, I'm sure it's the former but I'm just wanting to double check. If that's the case, can I use a coupler to go from 32mm > 50mm (50mm rather than 40 as I have spare pipe already) to allow a longer total length, obviously provided the fall is okay. Thanks for any advice. Link to comment Share on other sites More sharing options...
Russell griffiths Posted March 12, 2024 Share Posted March 12, 2024 32mm under the sink, change to a larger pipe as quickly as you can, literally 50mm from the trap. Link to comment Share on other sites More sharing options...
JackofAll Posted March 12, 2024 Share Posted March 12, 2024 7 hours ago, Russell griffiths said: 32mm under the sink, change to a larger pipe as quickly as you can, literally 50mm from the trap. Am curious, why is that? Link to comment Share on other sites More sharing options...
Russell griffiths Posted March 12, 2024 Share Posted March 12, 2024 13 minutes ago, JackofAll said: Am curious, why is that? Because 32 is absolutely rubbish, it does not allow for a flow of water and bubbles or air, a larger bore pipe allows water to sit at the bottom and air to pass over the top. 32 really needs doing away with. 1 Link to comment Share on other sites More sharing options...
