Wet dash
JackofAll
Getting closer to plastering stage now, will be getting a crew in but am wondering which mix is better white sand, white cement, white chip (10mm) or grey sand, cement, any 10mm chip and lime. Looking for a bright white finish. If going the 1st mix is there need for lime? I know that whichever crew we go with will most likely know but would like to know for myself, thanks.
35 minutes ago, Mr Punter said:
With the first mix the lime won't make it much whiter but it may be a better consistency / easier to work with.  Can you make up sample batches?
Good idea, though would require buying a bag of each(tight git I am 🙂 )
I’ve wet dashed ours with K Dash
Ive several pumps that spray the dash but my wife wanted it more random Like I used to do 30 years back in the Lake District White cement Silver sand
3-1-1
The silicone renders keep there colour better
  • Like 3
3-1-1
24 minutes ago, JackofAll said:
You used the white cement in the scratch coat too? What size chip did you go for Nod, it's a fine looking house.
No. This is K dash
But no You don’t need white cement or silver sand in the scratch coat
  • 2 months later...
Chatting to plasterer re wet dash, he asked how many coats the were specified. My understanding is scratch coat and butter coat, the dash is then applied as the butter coat as it is going off(though not exactly sure when that is) am I wrong? He said its alot of extra expense whereas if he applies a thick scratch coat then dash onto that. Any advice? Also what is the idea of the butter coat?
18 hours ago, JackofAll said:
Chatting to plasterer re wet dash, he asked how many coats were specified. My understanding is scratch coat and butter coat, the dash is then applied as the butter coat as it is going off(though not exactly sure when that is) am I wrong? He said its alot of extra expense whereas if he applies a thick scratch coat then dash onto that. Any advice? Also what is the idea of the butter coat?
* should have read "to the butter coat". @nod can you shed some light on this, thanks.
Run a mile
He’s clueless
