JackofAll Posted March 5, 2024 Share Posted March 5, 2024 Getting closer to plastering stage now, will be getting a crew in but am wondering which mix is better white sand, white cement, white chip (10mm) or grey sand, cement, any 10mm chip and lime. Looking for a bright white finish. If going the 1st mix is there need for lime? I know that whichever crew we go with will most likely know but would like to know for myself, thanks. Link to comment Share on other sites More sharing options...
Mr Punter Posted March 5, 2024 Share Posted March 5, 2024 With the first mix the lime won't make it much whiter but it may be a better consistency / easier to work with. Can you make up sample batches? Link to comment Share on other sites More sharing options...
JackofAll Posted March 5, 2024 Author Share Posted March 5, 2024 35 minutes ago, Mr Punter said: With the first mix the lime won't make it much whiter but it may be a better consistency / easier to work with. Can you make up sample batches? Good idea, though would require buying a bag of each(tight git I am 🙂 ) Link to comment Share on other sites More sharing options...
nod Posted March 5, 2024 Share Posted March 5, 2024 I’ve wet dashed ours with K Dash Ive several pumps that spray the dash but my wife wanted it more random Like I used to do 30 years back in the Lake District White cement Silver sand 3-1-1 The silicone renders keep there colour better 3 Link to comment Share on other sites More sharing options...
nod Posted March 5, 2024 Share Posted March 5, 2024 1 minute ago, nod said: I’ve wet dashed ours with K Dash Ive several pumps that spray the dash but my wife wanted it more random Like I used to do 30 years back in the Lake District White cement Silver sand 3-1-1 The silicone renders keep there colour better 2 Link to comment Share on other sites More sharing options...
Mr Punter Posted March 5, 2024 Share Posted March 5, 2024 1 hour ago, JackofAll said: Good idea, though would require buying a bag of each(tight git I am 🙂 ) Thirty quid for a couple of grands worth of render. Link to comment Share on other sites More sharing options...
JackofAll Posted March 5, 2024 Author Share Posted March 5, 2024 3 hours ago, nod said: You used the white cement in the scratch coat too? What size chip did you go for Nod, it's a fine looking house. Link to comment Share on other sites More sharing options...
JackofAll Posted March 5, 2024 Author Share Posted March 5, 2024 2 hours ago, Mr Punter said: Thirty quid for a couple of grands worth of render. True story, will do it when we sort the windows, thanks. Link to comment Share on other sites More sharing options...
nod Posted March 5, 2024 Share Posted March 5, 2024 24 minutes ago, JackofAll said: You used the white cement in the scratch coat too? What size chip did you go for Nod, it's a fine looking house. No. This is K dash But no You don’t need white cement or silver sand in the scratch coat 1 Link to comment Share on other sites More sharing options...
JackofAll Posted May 8, 2024 Author Share Posted May 8, 2024 Chatting to plasterer re wet dash, he asked how many coats the were specified. My understanding is scratch coat and butter coat, the dash is then applied as the butter coat as it is going off(though not exactly sure when that is) am I wrong? He said its alot of extra expense whereas if he applies a thick scratch coat then dash onto that. Any advice? Also what is the idea of the butter coat? Link to comment Share on other sites More sharing options...
JackofAll Posted May 9, 2024 Author Share Posted May 9, 2024 18 hours ago, JackofAll said: Chatting to plasterer re wet dash, he asked how many coats were specified. My understanding is scratch coat and butter coat, the dash is then applied as the butter coat as it is going off(though not exactly sure when that is) am I wrong? He said its alot of extra expense whereas if he applies a thick scratch coat then dash onto that. Any advice? Also what is the idea of the butter coat? * should have read "to the butter coat". @nod can you shed some light on this, thanks. Link to comment Share on other sites More sharing options...
nod Posted May 9, 2024 Share Posted May 9, 2024 19 hours ago, JackofAll said: Chatting to plasterer re wet dash, he asked how many coats the were specified. My understanding is scratch coat and butter coat, the dash is then applied as the butter coat as it is going off(though not exactly sure when that is) am I wrong? He said its alot of extra expense whereas if he applies a thick scratch coat then dash onto that. Any advice? Also what is the idea of the butter coat? Run a mile He’s clueless 1 Link to comment Share on other sites More sharing options...
JackofAll Posted May 9, 2024 Author Share Posted May 9, 2024 Got that impression, just needed confirmation, so is it correct to dash onto butter coat as it's going off? Link to comment Share on other sites More sharing options...
nod Posted May 9, 2024 Share Posted May 9, 2024 Scratch coat If sand and cement leave for three days Then a tight coat and dash 1 Link to comment Share on other sites More sharing options...
nod Posted May 9, 2024 Share Posted May 9, 2024 6 hours ago, JackofAll said: * should have read "to the butter coat". @nod can you shed some light on this, thanks. Butter is Receiver coat 1 Link to comment Share on other sites More sharing options...
