Jamc Posted March 3, 2024 Posted March 3, 2024 Hi all, I have inherited my 2500sqft plus family home, it's an old stone farm house, recently renovated in 2000 with new roof, electrics and plumbing, but unfortunately still a very cold house/ with damp issue. Any way is there any experience making this kind of building more renewable and warmer. I was thinking of underflow heating etc but maybe this is too costly and better making it more 'air tight'. The windows are double glazing but poor quality.
TonyT Posted March 3, 2024 Posted March 3, 2024 best do a heat loss calculation to see how much heat is required. look at faulty down pipes rainwater goods, external ground levels for damp. consider additional ventilation in areas that generate moisture? 1
Galileo Posted March 3, 2024 Posted March 3, 2024 Wonder if that renovation 24 years ago was done with any sympathy to an old stone building with for example a water permeable lime mortar etc? There seems to be a rule: air tight + stone house = damp 1
Jamc Posted March 3, 2024 Author Posted March 3, 2024 I'm no expert, but I seen this a lot in Grand Designs, I doubt there was any sympathy for the stone and the internal walls were a standard plastering
Susie Posted March 3, 2024 Posted March 3, 2024 Are any rooms less damp than others or some specific areas more damp. 1
Galileo Posted March 4, 2024 Posted March 4, 2024 Take a look at this post Historic Scotland has some good reading on this: https://www.historicenvironment.scot/archives-and-research/publications/publication/?publicationId=179c1909-3679-4486-9583-a59100fa98c1 There is a guy called Peter Ward that has a Youtube channel (and a book) talking about damp in old stone houses. Tread with caution though, his views do not align with a number of companies in the damp proof industry who he vigorously slates and I do not have the technical ability to say who is right: https://www.youtube.com/@WarmDryHome
Roger440 Posted March 4, 2024 Posted March 4, 2024 A damp house will always feel cold Damp walls are a thermal disaster. Fix the damp (as suggested above) then worry about the heating. Sadly, its a minefield.
saveasteading Posted March 4, 2024 Posted March 4, 2024 1 hour ago, Galileo said: Historic Scotland has some good reading This is a good, and very sensible document, and there is more from them , but I've lost track of it. You don't need any specialist damp proofing, in fact it may cause problems. Our steading , as most stone buildings , has 2 masonry skins filled with rubble and mortar. This stops most dampness and even has some useful thermal resistance. As it is mostly granite, no rain gets into the stone, and a tiny amount will soak into the outer mortar then soon disappear again. We built an insulated, damp protected, timber skin inside it. It was a shame to completely hide the masonry internally but it is the only way really. similar construction under the slate roof which we retained. We did leave a feature area of wall exposed, with the bco permission. We now have a building to new-build insulation standards, even though less was permissible. Cosy and dry right through its first winter as a dwelling.
