flanagaj Posted February 27, 2024 Posted February 27, 2024 I really like the industrial look of concrete casting, and am thinking of having a single wall in the entrance hall with a floating staircase. Is it a case of adding some vertical rebar from the slab and building a strong plywood form. Just concerned that there is no leakage of bleed water, otherwise, it can look terrible. Any other options?
nod Posted February 27, 2024 Posted February 27, 2024 I do quite a few jobs in clay works The concrete look is all the rage amongst the designers Not cheap but cheaper than casting a whole wall
flanagaj Posted February 27, 2024 Author Posted February 27, 2024 14 minutes ago, nod said: I do quite a few jobs in clay works The concrete look is all the rage amongst the designers Not cheap but cheaper than casting a whole wall Do you have a link. I briefly dabbled in casting concrete clocks / furniture using GFRC, so could always manufacture large 20mm thick wall panels, but would prefer the look of a cast wall.
