Alwayslearning22 Posted February 15 Share Posted February 15 Hi folks I have had a new door fitted and the guys that did it weren’t the best. The house is owned by a housing assoocation and they don’t care too much about there houses to be honest. I’ve attached pics of the way it was fitted. it’s a Upvc door set and they fitted flush to the vertical battons no problem there. Then they propped up the bottom of the door which has a low threshold attached to it with a Batton. They didn’t use a sill. told me didn’t need one and batton will do the job. Is this done correctly? As it’s a bit draughty I’d love to improve it to be more airtight. Link to comment Share on other sites More sharing options...
Alwayslearning22 Posted February 15 Author Share Posted February 15 Link to comment Share on other sites More sharing options...
markc Posted February 15 Share Posted February 15 If the draught is coming up through the gap I would say it wasn’t sealed underneath the new door. Pretty easy to fill the gap under the door and the strip inside. If draught/s are coming around the side, pull the cover strip off and fill the side and top gaps they probably left. Link to comment Share on other sites More sharing options...
