jpadie Posted February 12, 2024 Posted February 12, 2024 Hi I am struggling to thread about 20m of 63mm MDPE down a 110mm pipe that's being repurposed as a duct. Are there any tips that might make things a little easier? there's a mild S bend in the middle and I think I may be getting stuck there. there's no easy way to get hot water into the pipe unfortunately. at the moment the leading edge is stopped up. I was thinking about removing the stop and cutting an angle there. it will be connected to a pump so any silt should get blasted out. thanks in advance. justin
markc Posted February 12, 2024 Posted February 12, 2024 Hi, you won’t push it through, really needs pulling. Drain rods through first then use them to pull a rope through, then use rope to pull mdpe through. if you have a decent size compressor then air can be used to blow the rope through in place of drain rods.
jpadie Posted February 12, 2024 Author Posted February 12, 2024 thank you. i don't have drain rods or a compressor (in the UK) sadly! or a long enough rope! and there's a belly in the duct that holds water. getting a rope through is going to be tough but I see the point. I do have a 20m fish tape. that might be good enough to pull back a rope.
