Green roof DIY instal - any good supplier tips
markharro
4 hours ago, markharro said:
should also be a good feature
Bear in mind maintenance. Plants grow and die so may need maintenance and you need safe access.
The membrane has to be roof resistant. Some of these are not uv resistant so perhaps a joint is required.
Consider laying a grid to contain the plants.
This is all very heavy (wet earth) and the roof needs to be designed for it.
