Just after a bit of a sanity check, or correction please.
I've run unterminated my cables to the approximate Camera location, I'm pondering over what to do with regards cable meets camera...  I'm thinking terminate the main cable into a faceplate inside the building then run a shortish patch lead  from the faceplate through the blockwork to the camera, alternatively run the cable straight out and have a junction box of sorts at the camera with splice kit buried in it.
What would you do?
