Ideas about how to setup air heat pump, supported by PV's, for the highest cost efficiency during winter
21 minutes ago, Gone West said:
The problem, when there are many variables, is knowing the effects of one of the variables on the others.
Where statistics comes in.
You probably already have a fairly food idea of how much you use, and when, so a basic model would get you halfway there.
Statistics needs data. Where do I get data on the effects of different types of size and shape of the tank and different size, type and position of the heating coil in the tank, on the efficient extraction of heat from the boiler output. So the boiler can run in condensing mode to fill most of the tank with useable hot water for heating radiators.
You get it from what you already measure, or can measure easily.
Use the manufactures data for the rest and create scenarios.
You make it sound so easy!
Be handy if i could do it.
I blame my maths teachers.
