The Dude Posted January 4, 2024 Share Posted January 4, 2024 Hi, Our house was previously extended but the previous owners did not remove the old exterior wall lintel meaning we have a constriction of around two foot were the old exterior walls protrude into the room each side and about one foot from the ceiling. We want to remove the old lintel, raise it above the ceiling line and get rid of as much of the old walls as possible increasing the gap from around 6 foot to 8 foot. The builder has recommended a structural engineer (which is good!) He wants to support the exterior wall using strongboys rather than needles. I appreciate it is a lot less work to use strongboys but I am concerned they are not sufficient to support the storey above. Will a structural engineer be able to advise how the wall should be supported during the work? Link to comment Share on other sites More sharing options...
joe90 Posted January 4, 2024 Share Posted January 4, 2024 2 minutes ago, The Dude said: Will a structural engineer be able to advise how the wall should be supported during the work? Yes Link to comment Share on other sites More sharing options...
Mr Punter Posted January 4, 2024 Share Posted January 4, 2024 1 hour ago, The Dude said: Will a structural engineer be able to advise how the wall should be supported during the work? Temporary works are normally the responsibility of the main contractor but you can ask the SE to design this for an additional fee. Link to comment Share on other sites More sharing options...
nod Posted January 4, 2024 Share Posted January 4, 2024 I’ve taken lots of supporting walls down in my time Some with strong boys others with needles Whilst Strong boys are more convenient Needles are belt and braces I can see why your builder would prefer strong boys But I would use a couple of needles I suspect a SE would air on the side of caution also Link to comment Share on other sites More sharing options...
