johnannik Posted January 3, 2024 Share Posted January 3, 2024 I have an overgrown garden. The small wall is tipping, what do you recommend I do? Could I remove some of the soil and prop the wall small wall back up, or will I have to remove and re-build? What would you suggest? Thanks Link to comment Share on other sites More sharing options...
Mr Punter Posted January 3, 2024 Share Posted January 3, 2024 No it will need rebuilding. Link to comment Share on other sites More sharing options...
johnannik Posted January 3, 2024 Author Share Posted January 3, 2024 19 minutes ago, Mr Punter said: No it will need rebuilding. OK, Would I be able to reuse the bricks do you think? Link to comment Share on other sites More sharing options...
joe90 Posted January 3, 2024 Share Posted January 3, 2024 Yes if the mortar is not too hard to clean off. Link to comment Share on other sites More sharing options...
Conor Posted January 4, 2024 Share Posted January 4, 2024 Might not be worth the effort. You'll need to build something more substantial. E.g. concrete blocks on their flat with facing brick. You'll need to dig the lot up and put in better footings, maybe some drainage. You might want to redo the patio while you're at it. Or just get rid of the wall, slope the soil back and just have a simple pin kerb edging the paving. Link to comment Share on other sites More sharing options...
