mwildy Posted January 3, 2024 Posted January 3, 2024 Hi All I'm at the early stage of planning a loft conversion and have a question regarding the ridge board. Is there any way to have a shed (pitched roof) dormer going to the existing ridge board rather than having to install a ridge beam. I recall reading somewhere that it could be done if the pitch was a minimum of X. Many thanks in advance Mike
Russell griffiths Posted January 3, 2024 Posted January 3, 2024 Diagram or pictures needed you will always get a better response with a drawing added.
mwildy Posted January 3, 2024 Author Posted January 3, 2024 Gable roof Detached House 7m deep internal 9.5m wide internal, 16 trusses 2.7m height (joist to rafter) Loft staircase over existing staircase and shed dormer to rear set back at least 20cm: Telebeams for removal of trusses: Most UK dormers seem to be flat roof, but in order to minimise disruption, cost, headroom and aesthetics, I was wondering if this would be possible: Thanks Mike
kandgmitchell Posted January 3, 2024 Posted January 3, 2024 Not quite as easy as it looks. You have trussed rafters which are lightweight factory made frames which distribute loads within themselves and are further strengthened by being part of an overall structure braced with horizontal and diagonal members. You cannot simply cut away the inconvenient bits. The principle you show may be possible but it will need to be designed by a structural engineer to ensure it doesn't all come apart at the seams......
mwildy Posted January 3, 2024 Author Posted January 3, 2024 1 hour ago, kandgmitchell said: Not quite as easy as it looks. You have trussed rafters which are lightweight factory made frames which distribute loads within themselves and are further strengthened by being part of an overall structure braced with horizontal and diagonal members. You cannot simply cut away the inconvenient bits. The principle you show may be possible but it will need to be designed by a structural engineer to ensure it doesn't all come apart at the seams...... This is what the telebeam system is designed for https://www.telebeam.co.uk
Mr Punter Posted January 3, 2024 Posted January 3, 2024 Have you tried contacting TeleBeam? They should be able to provide you with a quote and the design and calcs will be included in the price.
mwildy Posted January 3, 2024 Author Posted January 3, 2024 4 minutes ago, Mr Punter said: Have you tried contacting TeleBeam? They should be able to provide you with a quote and the design and calcs will be included in the price. Only just learned that they may well advise on all aspects and not just the floor and truss removal, which would be a win! Awaiting their reply. 1
Mr Punter Posted January 3, 2024 Posted January 3, 2024 A friend of mine is looking at these. It looks a clever system and saves getting heavy steels in. Not sure how expensive though. Can you update this post with the price when you get it?
mwildy Posted January 3, 2024 Author Posted January 3, 2024 9 minutes ago, Mr Punter said: A friend of mine is looking at these. It looks a clever system and saves getting heavy steels in. Not sure how expensive though. Can you update this post with the price when you get it? I have 16 trusses (so 32 telebeams required) each covering a span of 7m (TB7.0 https://www.telebeam.co.uk/images/pdfs/generic_cross_section_2017.pdf) Then; stairwell trimming hangers, bolts, sole plate angle fixings, stainless steel screws, drawings and instructions: £9,911.00 plus VAT 1
mwildy Posted January 3, 2024 Author Posted January 3, 2024 1 hour ago, mwildy said: I have 16 trusses (so 32 telebeams required) each covering a span of 7m (TB7.0 https://www.telebeam.co.uk/images/pdfs/generic_cross_section_2017.pdf) Then; stairwell trimming hangers, bolts, sole plate angle fixings, stainless steel screws, drawings and instructions: £9,911.00 plus VAT How much would steels cost in comparison roughly?
olley Posted August 25, 2025 Posted August 25, 2025 Our adjoining semi neighbour used tele beams, he's supporting the new ridge with two columns equidistant across the 10m length of the bungalow, because he's got these two columns he was able to use timber for the new ridge.
