Is there a way to connect this to my LED driver?
I was wanting to be able to dim the under cabinet lights with it.
If not, any solutions??
Wired it up as per instructions and working ok - can you confirm my wiring is correct? (Not a sparky!)
Full brightness is halfway on dimmer which is fine unless I need to change that.
If it works that is great.  To be sure the dimmer must be an LED dimmer, and both the transformer and the lamps must be "dimmable"
