Ah you'll need some insulation then.
3 options.
1. Knock the wall and build the whole thing from scratch with a timber frame.
2. Use bricks to build the wall higher a d forget the timber frame.
3 Use your hybrid approach.
For 2 and 3  I would put 50mm PIR internally, foamed and taped at the joints.Then a 22*70mm battened service cavity and plasterboard.
Joining the wall PIR to 50mm (or more)PIR on the floor. Overlay with 2*11mm layers of floating OSB, joints staggered, glued and screwed.
7 hours ago, ColdOutside said:
That’s pretty much the plan. Is the 70mm battens to allow a 20mm air gap?
If you're willing to loose more space you could use 44*47mm battens @400cc for a service cavity and then infill with mineral wool.
The 22*70mm is to create an uninsulated service cavity. (The stationary air will help insulation almost as much as insulation at narrow depths anyway) the reason for not using 22*44mm battens is they'll split from the plasterboard screws.
You could add external insulation to protect the frame from wasps a little. Also an insect screen is useful. I’m using both, the insect screen also needs to be sealed top and bottom with stainless steel mesh
On 03/01/2024 at 18:22, ColdOutside said:
Yeah not too much room so 70mm is about max. Using a osb finish internally not plaster board.
50mm PIR.
11mm ply ripped into strips for service cavity battens.
11mm OSB Finish.
