Garald Posted December 27, 2023 Posted December 27, 2023 Hi, So, I'll go through with my project - installing sliding windows 15cm outside sound-reducing windows (since that seems to be the only way to really deal with the lower frequencies). Let me ask some questions before I give my agreement to the quote: - Having the thermically weaker window on the outside actually prevents condensation, no? (Why?) I'm attaching the technical information for the existing windows. The glass in the sliding windows would be of type STADIP Protect 88.4, as in the table https://befr.saint-gobain-building-glass.com/sites/saint-gobain-building-glass.com/files/documentPdf/STADIP PROTECT P4A Cahier des charges.pdf - Should I insist on having some sort of sound absorber on the sides of the 15cm-thick space? Right now that's mostly brick. DoP_d2601503_20221016 (7).pdf
Mike Posted December 31, 2023 Posted December 31, 2023 On 27/12/2023 at 23:24, Garald said: installing sliding windows 15cm outside sound-reducing windows In the UK it's normal to have the double glazed unit on the outside and the sliding secondary window inside, but that's no-doubt because UK windows are normally outward opening. On 27/12/2023 at 23:24, Garald said: installing sliding windows... ...(since that seems to be the only way to really deal with the lower frequencies) Not the only way. In Europe I seen a full double window used. That is, an inward opening double-glazed window internally, and an outward opening double-glazed window externally - which worked very well, acoustically. If using a sliding window externally, check that the weather sealing will be adequate. On 27/12/2023 at 23:24, Garald said: Having the thermally weaker window on the outside actually prevents condensation, no? (Why?) I've not come across that as a recommendation and it wouldn't be the case in the normal UK situation. On 27/12/2023 at 23:24, Garald said: Should I insist on having some sort of sound absorber on the sides of the 15cm-thick space? Right now that's mostly brick. The air is going to be transmitting most of the sound, so IMO it's not necessary.
Garald Posted January 1, 2024 Author Posted January 1, 2024 13 hours ago, Mike said: In the UK it's normal to have the double glazed unit on the outside and the sliding secondary window inside, but that's no-doubt because UK windows are normally outward opening. Right - outward opening windows are called "English windows" over here, and sell for a premium. 13 hours ago, Mike said: Not the only way. In Europe I seen a full double window used. That is, an inward opening double-glazed window internally, and an outward opening double-glazed window externally - which worked very well, acoustically. Well, this *will* be a full double window - each window will have a (supposedly) decoupled frame and so forth. I can't have quite the arrangement you mention (which I think is exactly what I had in my office when I worked in Germany) as there is a railing outside the window. 13 hours ago, Mike said: If using a sliding window externally, check that the weather sealing will be adequate. This is meant to be a quality window frame - see https://www.technal.com/fr/fr/accueil-professionnels/les-produits-technal/la-fenetre-et-porte-fenetre/
Mike Posted January 1, 2024 Posted January 1, 2024 9 hours ago, Garald said: This is meant to be a quality window frame - see https://www.technal.com/fr/fr/accueil-professionnels/les-produits-technal/la-fenetre-et-porte-fenetre/ To check, they should have published the AEV ratings - see https://fr.wikipedia.org/wiki/Technique_des_portes_et_fenêtres#Classement_AEV
Garald Posted January 1, 2024 Author Posted January 1, 2024 3 hours ago, Mike said: To check, they should have published the AEV ratings - see https://fr.wikipedia.org/wiki/Technique_des_portes_et_fenêtres#Classement_AEV Right: Perméabilité à l’air : Classe 4 / Q4 : 0.19 m3 /(h.m²) Étanchéité à l’eau : Classe 6A Résistance à la pression du vent : Classe B2 https://stdrawings.blob.core.windows.net/sapamediagallery/doc6x91gouk8k9uc75lcv3-doc This seems to mean: - permeability: very good - waterproof rating: medium high - wind resistance: medium low , no?
Mike Posted January 1, 2024 Posted January 1, 2024 3 hours ago, Garald said: This seems to mean: - permeability: very good - waterproof rating: medium high - wind resistance: medium low Yes, that looks right.
