jayc89 Posted December 18, 2023 Posted December 18, 2023 Got a Rehau Rio to fix. One side opens, the other side is fixed, but it looks as if it should open, so there's quite a depth to screw through, which doesn't feel right, does the fixed side somehow come out so I can screw through the frame only? (I know lugs would be better than screwing through the frame, but apparently they're not available for Rios...
Russell griffiths Posted December 18, 2023 Posted December 18, 2023 Flat steel plate with multiple holes in it, available from most builders merchants, screw this to the frame to use as a bracket, not the thin builders band, these are 75mm x 120mm flat plate. You can cut it into 2-3 bits if you want.
jayc89 Posted December 18, 2023 Author Posted December 18, 2023 Figured it out. Turns out the fixed section, isn't fixed, rather it's a top guided window that's screwed shut (no locking mechanism). I wish I had thought of @Russell griffiths suggestion ahead of time though!
