richo106 Posted December 14, 2023 Posted December 14, 2023 Good Morning I will need to plaster onto cement boards, the cement boards are quite smooth and guessing high suction Will i need to prime it or green grit it (gypsum bond-it)? Any ideas/advice on this please Many Thanks
MikeGrahamT21 Posted December 14, 2023 Posted December 14, 2023 From memory i think its SBR bond you'd need in this case, sure someone will come along and confirm
Barnboy Posted December 18, 2023 Posted December 18, 2023 I'm planning on plastering onto Jackoboard, I called their technical guy who told me to prime with sbr and then plaster away .
richo106 Posted January 19, 2024 Author Posted January 19, 2024 https://www.screwfix.com/p/bostik-sbr-admixture-white-5ltr/91566 Is this the correct SBR primer? Do i just roller it on neat? OR does it need diluting? Would the plasterers need to use multi finish or would board finish be ok? Thanks again
Barnboy Posted January 20, 2024 Posted January 20, 2024 The guy at Jackoboard told me to use SBR, he didn't say anything about diluting it, but I also didn't ask, and I'm not at the point of plastering yet so il jabe to.look firther. Give the their technical helpline a call, they were quite easy to talk to. If I remember correctly the plasterer said he'd just use multifinish over it, the same as the rest if the walls.
Kelvin Posted January 20, 2024 Posted January 20, 2024 It doesn’t say anything about prep on their website instead it suggests you can plaster straight on to it. Although I only have a small triangle to plaster over that covers part of the stairs in a wardrobe.
