Hi All
I'm running in some first fix pipework for the shower,
What would be a good height to mount,
Wall mounted Shower handset outlet, before it attaches to a hose, Similar -->
Wall mounted rainfall connection arm similar -->
Ta
Marek
How tall are you or other users? Shower head needs to be above your head and valves/handset at a height convenient for all
Height, about 1.8 ish
Thinking of mounting the arm at about 2-2.1m, Haven't got it yet, but I guess I ought to see how much of a curve it has before the shower head.
The handset will be attached to a riser.
I wondered if there was a general rule of thumb?  If I mount at the same height as the main valve control box then it shouldn't look too out of place!  The V box is on another wall out of the main shower area.
we held up our riser bar while we were both standing in the area and said 'about there will do'. very scientific! for our iBox controls we were a bit dictated by the noggin in the timber wall at about 1200mm and I couldn't be bothered to move it so we plumped for the controls to be at about 1100mm. seems about right for us but we're all pretty short! 😆
Spot on!  I'm just roughing pipework in at the moment, and ready to put some noggins in for the wall plates elbows.  I may toddle off to a bathroom showroom aswell and measure what their outlets are set at, I'm also thinking that housebuilders dont always get to see end customers so must have a rule of thumb regarding heights too.
How did you work out depth for the wall plate elbows for the outlets taking into consideration tiles, adhesive, backer board?
I think that now I'm onto using 20mm backer rather than PB, I've got to move my control box forwards a touch, trivial but another task on the list.
I tried to get the elbow to finish a few mm back from the finished tile face which was recommended on a thread on here.
