Hi.
My neighbour had a flat foof put on his extension in early September 2023.
He loves it but doesn't know much about glass fibre.
The builders put 1 layer of glass fibre matting on it 4 weeks ago but haven't topcoated it.
It's too late to get a proper bond after 4 weeks surely?
Why would anyone wait so long to topcoat?
Just wondering.
Edited by DaveAF
Just needs a good rub down with fine sandpaper and it'll be fine. Topcoat in theory protects against UV damage, otherwise aesthetic. Looks like a pretty good job btw.
FFS
Just as well they have not put the top coat on.  1 layer is bugger all and will quite possibly cause problems in the not too distant future.
If they use the right kind of resins, adding extra layers and a top coats onto fully cured substrate is not a problem.
I will say that it does look a reasonable layup for 1 layer, nice and resin rich, which is a good thing.
11 hours ago, SteamyTea said:
FFS
Any kit I've ever used has been a specific one layer chopped strand kit. I didn't know multi layer was a thing.
12 hours ago, SteamyTea said:
FFS
Oddly enough after they repaired a minor leak yesterday morning they finally topcoated the roof. No extra layers of matting though, just a paint over with the topcoat.
2 layers of 450g/m2 CSM would be normal, I would always recommend 3 layers.
As a general rule, 1 layer of 450g/m2 matt is 1 mm thick and will take 900g of polyester resin.  If going onto a very absorbent substrate like OSB, then the first layer will take more resin.
Topcoat is around 350g/m2.  This can vary quite a lot depending on the final usage i.e. aviation and walkways are treated very differently.
