jayc89 Posted October 17, 2023 Posted October 17, 2023 Wardrobe/ensuite area. Posi joists are in place and I was planning on glueing and screwing 22mm P5 (Caberdek) boards to it. I want to lay an UFH mat and tile it, and have read that P5 isn't great for that. If I shouldn't use the P5 boards, what should I use instead; 22mm ply T&G?
jayc89 Posted October 17, 2023 Author Posted October 17, 2023 9 minutes ago, nod said: It makes little difference I'd much prefer to use P5 as I already have the stuff, but I thought there were concerns around adhesive sticking to the chipboard? What would a typical build up look like if tiling onto caberdek? SBR primer, durabase/ditra, heating mat, tiles?
jayc89 Posted October 17, 2023 Author Posted October 17, 2023 Reading through a few tiling forum pages, it seems like this might be typically used; - p5 deck - SBR primer - heating mat - SLC to cover the mat (approx 3mm) - decoupling membrane - tiles Does that sound sensible? Whilst the joists have been spec'd for less than 7mm deflection (4m span), I'm worried the SLC might be too brittle. Would a renovation screed like Mapei's 3240 be more suitable?
jayc89 Posted October 18, 2023 Author Posted October 18, 2023 Any words of wisdom before I go down this route? @Nickfromwales @nod?
